starts then dies, then turns over but no start.
Old Oct 10, 2005 | 07:30 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
To clearify on the topic, my '91 Z will start and idle for about 10 seconds then it dies, and will not start after that but will turn over. If I wait a few minutes between start attempts, it will fire up, but does the same thing.
Wierd thing is that I am getting a code 22 (TPS)-which is what I origionally associated the problem to when it started a couple of days ago. However, then it would at least start back up right away, but would die at idle. Bow it is far past that but still shooting the code.
Standard checks are good-plugs wires, new cap&rotor, all sensors plugged in and new tps. Jacob's ignition as well. I have a spare ignition module somewhere around here I am going to swap in.
Big question is I suppose, how could not starting be linked to the TPS? Even if a wire was grounding out, it should still shoot the error and go into limp home mode, right? Or does it have to be in the ignition?
Thank you for any advice
Old Oct 10, 2005 | 07:32 PM
Engine: LO3;383tpi
I should also note that fuel pressure is verified. And I am way out in the "sticks" and haven't had a second pair of hands to atually check for spark on the start-up attempts
Old Oct 10, 2005 | 08:25 PM
Engine: LO3;383tpi
Well, changed the ignition module, it's not that. What else could it be? A bad ignition box? If it was the coil it probably wouldn't start at all, right?
Old Oct 10, 2005 | 08:59 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If TPS reads high it will send the code into "clear flood" mode and no fuel will be injected.
Take another look at that TPS and maybe fool the input to only see 1/2 volt. Should make it start if that is the cause.
Old Oct 10, 2005 | 10:17 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
hey i haid similar problem on my 87 tpi, i suggest u take of the throttle body, clean it ( blades clean no carbon)clean the iac passage ways then reset the iac, and give it a try fixed myn right up
throwing in my .02
Old Oct 11, 2005 | 11:36 PM
Engine: LO3;383tpi
Thank you for the help guys. Got her running again.....until next time she breaks down One day I will have all the kinks worked out!
Old Jun 20, 2006 | 10:31 PM
Critchie's Avatar
Car: 92 longbox s10
Engine: 305tpi
Axle/Gears: 3.42 posi
if you dont mind my asking what was the problem? im having this exact same issue in my 305 tpi swapped s10.
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
