camshafts
Old Oct 15, 2005 | 03:05 AM
SSprayd's Avatar
Car: '97 30th SS, '89 IROC-Z
Engine: LT4, LT1
Transmission: T56, 4L60E
camshafts
im looking to get a cam for my newly rebuilt 5.7 in my iroc but i dont wanna go big enough to where i gotta get a stall, heads worked, and chip burned and all that stuff due to funds. so what would be the best cam to put in a 5.7 w/ some bolt ons and go?!
Old Oct 15, 2005 | 08:07 AM
Vader's Avatar
Several people have had good success with the LT1 cams, with the increased lift and slightly longer duration. They are still very street freindly, yet allow more flow in the upper RPM ranges.
Old Oct 15, 2005 | 10:20 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Sounds to me like you are looking for the ZZ4 cam. Now that is if your heads can handle the extra lift. It gives good performance with a nice idle for the mods you have. If you have a MAF car you will not need a chip burned. Speed density, hard to say but it is a realtively mild cam so you might be able to slip by.
Old Oct 15, 2005 | 10:34 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Look at the LPE 213 cam's on eBay. Lingenfelter designed them for stock 350 TPI With stock heads. $100.00 Shipped is not bad for a nice Hyd roller cam.
Old Oct 15, 2005 | 12:22 PM
SSprayd's Avatar
Engine: LT4, LT1
my car is an MAF so what you said sounds good about the ZZ4 and the LPE 213 sound pretty good to me as well.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
