fuel pump
Old Oct 19, 2005 | 05:23 PM
roc city f body's Avatar
Car: 86 iroc z
Engine: 90 l98 vette
Transmission: 700r4w/all vette parts
fuel pump
first off i want to say i dont really know much about cars but i want to ask youguys, and i hope this is the right place for this.... i ran out of gas the other yesterday at a friends house(i know im a dumb ***) but anyways i went and put gas in it and tryed to start it and it would not start. now normally i can hear the hummmmm of the fuel pump befor i start it i was wondering if because i ran it dry did i f*ck up the fuel pump or something, please someone help i want to bring my car home
Old Oct 19, 2005 | 05:47 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
so when you turn the ignition on.. you're not hearing the pump prime for 2 seconds?
get yourself a helms manual.. check the fuel pump relay, check your fuses, and do a search on this board.. it could be a bunch of things.. but start with the easiest first and work your way up..
Old Oct 20, 2005 | 04:51 PM
Car: 86 iroc z
yeah i dont hear it, were can a noob get the helms manual?
Old Oct 20, 2005 | 07:40 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
ANY autoparts store.. can also get a chiltons if they dont have helms.. 14$
Old Oct 22, 2005 | 01:13 AM
Car: 86 iroc z
is it bad on the pump to run out of gas,cause until then it has started like a champ, thanks for helpin kill joy
Old Oct 22, 2005 | 12:26 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Check the fuse by the battery. Maybe it blew by chance.
Old Oct 23, 2005 | 09:38 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
have the fuel preasure checked at the rail. if you do not hear the pump and the relay is ok and there is no preasure dump the tank. I have to do it again and fight the 3in exaust because the aftermarket fuel tank from 1a auto is binding my fuel sender.
Old Nov 3, 2005 | 11:23 AM
Car: 86 iroc z
al right im kind of a newbee so where can i find this fuse? looking at a car engine is like understanding spainsh to me.
Old Nov 3, 2005 | 11:48 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
pop your hood.. look over by the battery.. there should be 2 thick wires (one red, one orange) going into a black box type weather pack fuse.. the black weather pack fuse should be bolted or attached to the fender.. pull the cap off and check to see if its blown.
Old Nov 4, 2005 | 07:21 AM
Car: 86 iroc z
thanks alot killjoy, gonna try that today the car is at my friends house so im gonna stop over later. i wil let you know whats up, and thanks again for your help!!!!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
