idle too high?
Old Oct 27, 2005 | 04:28 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
idle too high?
hi all, i've been searching threads,but not really coming up with the answer,on my 305 TPI (car in sig) the idle is too high,cold or hot really doesn't change,factory tach saying @1250 ,sometimes when warm enuf,while stopped at redlight i can rev it and it will come down to @1000 but go right back to @1250,the tach may not be real accurate,but the engines sounds like the tach is close,now starting to get SES light,sometimes comes on within 5 minutes of start and stats on the whole time driving,then sometimes it comes on,and goes out occasionally?? doing the paperclip test (engine was cold/sat about 6hours) got codes: 12,shows diagnostics working,then code 13,43,44 ,when doing this are you suppose to hear a noise like a fan is running??i believe my mileage has dropped dramaticly,@ 12 mpg in town,sure am missing my IROC should i go ahead and change the o2 sensor(13,44) or is the car just staying in open loop all the time,i can't seem to find a vacuum leak anywhere,and everything seems to be connected ok, sorry for long read,but any info is appreciated
Old Oct 27, 2005 | 06:52 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
anybody
in my camaro sevice manual,all 3 of the codes it's pulling are under the intermittent classification,i don't have the tools/knowledge to follow the procedure,needing a logical step in figuring this one out?,if it is in open loop the ecm does or doesn't control idle,is the TPS out of adjustment?the throttle cable not adjusted correctly??
Old Oct 27, 2005 | 10:18 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
did i put
these question in the wrong section?how do you move a post?
Old Nov 1, 2005 | 09:18 AM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
code43
code sheets show ESC(electronic spark control) which in turn knock sensor,but in autozone codes show as TPS out of adjustment which would explain my fast idle problem,would the code 43 from GM ESC knock sensor cause it,or is it the TPS?
Old Nov 19, 2005 | 10:26 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
it is your TPS your suffering the exact same thing i am right now lol i have my moms boyfriend out there workin on it lol.
but here is the site to go to and read about it.
http://www.iroczone.com/techarttpsadj.html
tahts how to adjust it when u get a new one cause you prolly will need a new one.
Old Nov 20, 2005 | 01:55 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Demonbird - Hwcoll's car is an SD TPI. The TPS on SD cars are NOT adjustable and under no circumstances should someone make it "adjustable".
Hwcoll - high idle is often a sign of vacuum leak, especially with the O2 sensor codes you are getting. It might be a gasket has gone somewhere on the intake (there's lots on a TPI car) or one of the rubber hoses from the vacuum ports maybe cracked.
Hope that helps.
Old Nov 20, 2005 | 02:22 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
You sir have a vac leak. Look harder. Check the orb of power and the HVAC controls. Can be hiding well. I like a non lit propane torch or starter fluid or TB/carb cleaner for finding vac. leaks. What did you use and how did you check?
Old Nov 21, 2005 | 12:13 AM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
vacuum leak
does seem like the next logical step,a piece of rubber hose and visible inspection are to no avail,but will have to spend more time on it,like the moron i can be i cleaned the TB and blades with carb cleaner while doing the visible,while shaking the carb cleaner,i got droplets on my headlight pockets, now more work to be done,i think i can just sand it and repaont those 5 little spots,also need to go ahead and pull the IAV valve and clean all that also
Old Nov 21, 2005 | 09:21 AM
Merlin's Avatar
Re: vacuum leak
Originally posted by hwcoll95
...also need to go ahead and pull the IAV valve and clean all that also
While you're in there, clean the throttle body where the IAC was residing. You might also want to clean the PCV. If you replaced the PCV recently, dig your old one out of the trash, clean it, and reinstall it. The replacement may be wrong for your engine. Been there.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
