SES light before startup?
Old Oct 27, 2005 | 07:46 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Ever since I got my car, the Service Engine Soon light comes on when i turn the power on. Is this normal? As soon as I start the car it goes off. Every once in a while I do get it though. I also have been having the high idle in park/stalling going into gear problem. I thought it would have been the IAC. I brought it to the mechanic (my dad didnt want me to do it myself ) and first he changed the idle motor. then he changed the MAT sensor. It still does it just less often. the thing is, now when i start it up when its a little cooler out, it wont stall warming up, itll keep revving a little when the rpms get too low. but still sometimes when I go into gear the car stalls if I dont give it gas, or even if I do, it will sometimes come back down too fast and die. maybe all these problems lead to something? Anyhow, my tranny died a couple weeks ago, and I tried to fix it. I replaced a couple broken things but still did not shift, so I am getting a new one this weekend. but when I took the car out to see if the parts worked it stalled really bad. I let it warm up or whatever, and when I put it in gear the idle got really rough and then died. Maybe all these problems are linked to one problem? thanks a lot for the help.
Old Oct 27, 2005 | 07:59 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Don't worry about it, its normal.
Old Oct 27, 2005 | 08:00 PM
ZZ4 86 Z28's Avatar
what about all the other times it comes on?
IROCtometal
Sep 9, 2015 10:01 AM
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
