chip problems
Old Oct 30, 2005 | 12:07 AM
84frbrd's Avatar
Car: 1985 trans am
Engine: 5.7 tpi
Transmission: 700-r4 with b&m trans pack
chip problems
alright i got a 85 t/a...350 tpi with aluminum heads, slp lower upper intake and runners, hooker headers, a built lower end msd the works, i go to put in my hypertech chip..(serial #-7777) ...and it makes the motor mess up reall bad, it wont even idel, is it because of the previous mods. i have dont to the motor or am i doing something wrong???? help please?
Old Oct 30, 2005 | 09:00 AM
Vader's Avatar
Are you using the original ECM (1226870) or have you upgraded the ECM?
Old Oct 30, 2005 | 09:59 AM
84frbrd's Avatar
Car: 1985 trans am
Engine: 5.7 tpi
original ecm..i didnt know their was an aftermarket one
Old Oct 30, 2005 | 11:20 AM
Vader's Avatar
An "upgrade" wouldn't necessarily be an aftermarket. I was asking about a later Delco ECM. The 1985 hardware does not address enough memory to support the depth of programming that 1986 and later vehicles enjoy. The 1990-later ECMs are even more configurable.
Aftermarket? AC/Delco (& eventually Delphi) have a lot more experience than any other company or organization in the world in vehicle control systems. Anything aftermarket would likely be inferior, or at least not as well researched and supported. Most of the other brands' OEM systems certainly are not.
If you want some detail about the differences and advantages of an upgrade, this might be interesting reading:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Street Lethal
Apr 30, 2019 12:14 PM
inferno15
Aug 29, 2015 01:48 AM
ambainb
Aug 29, 2015 12:43 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
