LB9 5speed goes 13.7 @100.5 with 2.1 60ft
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Just got back from the track yesterday, cooler air but I still suck at launching this thing. Just thought some of you guys might like to see some results. mods in the sig.
Car: 1983 G20 Chevy
Transmission: 4L60
Great accomplishment. It is always fun to kick a little *** with a 305.
Gotta love showing up guys that are supposed to have fast 350s. I beat a truck that had a "built" 350, wasn't that "built" I guess. Anyway good to see great times from fellow 305 owners.
For everyones reference, my 312 TBI would probably be running those numbers if it wasn't stuck in a 5,300 lbs G-Van. I've run a 9.89 @ 69.08 in the 1/8 with a 2.19 second 60' time.
I may have to swap to a TPI intake I have laying around with SLP runners, ported plenum, and ported base, with a 58 mm TB, just to see what the difference is at this power level. We can find out if TPI really is that much better.
The left lane was a stock newer VW beetle with a 2.0/ 4 cylinder/Automatic.
Gotta love showing up guys that are supposed to have fast 350s. I beat a truck that had a "built" 350, wasn't that "built" I guess. Anyway good to see great times from fellow 305 owners.For everyones reference, my 312 TBI would probably be running those numbers if it wasn't stuck in a 5,300 lbs G-Van. I've run a 9.89 @ 69.08 in the 1/8 with a 2.19 second 60' time.
Car: 86 IROC
Engine: 383
Thanks guys. It was a good time. As usual though, there was only one other thirdgen there. It was a tube chassis race car in the 8s. For some reason there are almost no thirdgens in this area, and the few that there are are mostly junkers. At the camaro superfest this summer I was really dissapointed at how slow most of the thirdgens were, mine was the fastest one there! thats pretty sad honestly.
Car: 86 IROC
Engine: 383
Smurfin Z28,
my cam specs are as follows...
214/224 .442/.465
My sig is actually misleading, I really should change it. The vette heads have the stock 1.94/1.50 valves (not even a 3 angle job on them
) The intake ports are gasket matched to a stock size intake gasket and simply smothed a bit, same with the bowls. The combustion chambers are polished and the exhaust ports are simply smoothed and polished. What I am saying is there was no real port work done, just a clean up of the heads as they came. I also used the .050" thick factory L98 head gasket.
I only got to make 4 passes saturday, the last 3 passes had 100.28, 100.37, and 100.48 mph respectively. Hopefully I can get my launch technique down a little better next spring and knock down some 13.50s. I know lower gears would make a difference but I kinda want to keep the 3.23s for autocross.
I know that TunedPort335 and mw66nova have turned quicker ETs naturally aspirated than me but they are running automatics and cutting 1.8 60ft times. Tim Burgess apparently ran in the high 12s but I know next to nothing about his combination except that he has a 305. Does anyone on here have a stick car in the mid 13s NA? I am sure there are I just cant think of anyone right off hand.
I am also wondering at what point the stock intake will become a hinderance. mw66nova is carb'd, TunedPort335 and myself are both running stock intakes, how much farther can we go?
214/224 .442/.465
) The intake ports are gasket matched to a stock size intake gasket and simply smothed a bit, same with the bowls. The combustion chambers are polished and the exhaust ports are simply smoothed and polished. What I am saying is there was no real port work done, just a clean up of the heads as they came. I also used the .050" thick factory L98 head gasket.I only got to make 4 passes saturday, the last 3 passes had 100.28, 100.37, and 100.48 mph respectively. Hopefully I can get my launch technique down a little better next spring and knock down some 13.50s. I know lower gears would make a difference but I kinda want to keep the 3.23s for autocross.
Originally posted by 1MeanZ
Smurfin Z28,
214/224 .442/.465
Smurfin Z28,
214/224 .442/.465
My car has a standard and is in the low 13s
but I have a little different motor
Seems like there was a guy either here or at cz28 a while back that had a 305 5 speed car running in the 12s.
Car: 86 IROC
Engine: 383
Dang, I'd like to find these guys and see what they are running. I can see the search button getting a workout already. My main question is what intake are they running. I would imagine they have to have low gears to get that ET out of a displacementally challenged 305.
Car: 1994 Jeep Wrangler
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I know my 13.4 runs were far from "perfect". i had a full size spare 215/65/15 and jack in the back of the car. 3/4 tank of gas and letting off the throttle a little bit for each shift, and hitting the rev limiter at the top of 2nd
I have since lightened the car a bit an added more fuel. i'd like to think i can crank a 13.1 or faster when i get the 3.42s in it. still on stock untouched 081 heads and TPI.
Car: 86 IROC
Engine: 383
well I had Drag radials on it, but I am an idiot and cant launch properly. I either did a good burnout and bogged the motor by dumpin the clutch, or I did not do a good enough burnout, slipped the clutch hard and spun the tires, hence the geriatric 2.1 60ft. I was suprised that this thing will really cook the 275/50/15 DRs even when they are aired down unless they are good and warm. I only got 4 runs so I am confident with a few more runs I would have gotten it dialed.
TunedPort335 I am amazed at your untouched heads. I suppose some of your power is a result of the extra cubes but dang there are guys with aluminum L98 heads on 350s that cant run your times. Oh well I suppose there are also people that dont believe that i am still runnin the stock chip.
BTW, didnt mw66nova run like a 12.95 a while ago? He has since hurt the engine however....
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Where can I get me a set of aluminum vette heads and what year will fit my 86 tpi 305?!?!? Dang man, if 13's are that easy, I'm all about modding my 305 a little.
Car: 86 IROC
Engine: 383
PneumaticTire: The heads you speak of are found on 87-92 corvettes, they #113 casting Aluminum heads. These heads are also known as ZZ4 heads, you can buy them brand new still.
Vette heads are not required to go in the 13s, I just did not want to port my iron heads. As Smurfin stated it is reasonably easy to get an LB9 5speed car in the high 13s with bolt ons. Automatics will have more difficulty getting there without gears and a converter. For some reason my car only ever trapped 96.5mph with the automatic, now it has ran 100.5mph with the only changes being an Edelbrock cat back and the 5 speed trans. Getting deeper into the 13s takes a bit more work than just bolt ons in most cases. TunedPort335 has stock heads but he has more cubes. mw66nova has converter, gears, ported heads i believe, and his car is light.
- time for some suspension work...My stick car is cutting 1.67 60's on 315/35/17 Nitto DR's. I do have a big stereo system in the trunk though, so that helps w/ over hang weight...
later, justin...
later, justin...
Originally posted by Scheister
wait a minute... why is it i ran 14.481 at 101.46... does that mean im getting no traction whatsoever?
well that makes me feel a lot better!
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Knock another 10th off that short time and you will pick up 2 10ths in the big end. That would net you a 13.5 Not too shabby for a little 305.
305!
Damn our Et and MPH are almost exact...
13.7-8 @99.5-100.5 mph 2.05 60' average
stick, Ported stock heads, 2030 CompuCam, Edelbrock shorties 2 3/4" ex, all free mods, March pullys 255whhp 352ft-lbs torque
Going to port stock Base to Accel runners and see the difference.
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Originally posted by SMURFN' Z28
you dont need vette aluminum heads to do 13s. All you need is bolt on LB9 5-spd car or a bolt on auto lb9 with a converter and a cam asumming you can get good traction. I dont imagine that 2.73 gears help much either.
Car: 86 IROC
Engine: 383
Re: 305!
No it made that power in May before the automatic took a crap.
I've been looking pretty hard to find one of these cars so far no luck but I anticipate a long search
darwinprice
17
Oct 11, 2015 11:51 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
