Maf
Old Nov 1, 2005 | 12:36 PM
scott 87z28's Avatar
Maf
I have been reading a few posts on the Mas air flow sensor.
I have read that on a 305 tpi they will disconect the sensor wire and the car still runs.
Here is a quote I found
( Disconnect the MAF sensor and watch your o2voltage. If it goes back up you likely have a defective MAF regardless if its new. They're pretty temperamental. Besides by your original post the problem started after the MAF was replaced.
Also if your idle smoothes out with the MAF disconnected it's probably gone south.)
When I do this to ours the car dies. and will not start.
is this correct? should it still run?
its a 1987 z28 I believe its a bosch unit.
thanks
scott
Old Nov 1, 2005 | 10:10 PM
anybody?
This must be a no brainier....
Mass air flow disconnected, will car run???
thanks
Scott
Old Nov 1, 2005 | 10:39 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It should run, but not well, at all.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
