dropping the fuel tank?
Old Nov 10, 2005 | 04:22 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im in the process or removing my fuel tank to replace the fuel pump....anything I should watch out for? Im going to have to cut my muffler off so the tank can drop out....do I have to remove the panhard bar and the bar above that? and all the freaking heat shields that are under car covering the tank? also I was told that there are 2 bolts in the trunk area that I need to get to from inside the car by removing the back carpet...is that true?
Old Nov 10, 2005 | 05:17 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Re: dropping the fuel tank?
If you unbolt the bottoms of the shocks and let them hang down you don't have to do this. I currently have my tank down for some custom work I'm doing, here's a pic where you can see everything I had to unbolt/remove:
Old Nov 10, 2005 | 05:25 PM
Guest
Guest
Posts: n/a
Cut the muffler off?
I unbolted the exhaust from the car and at the cat and pulled the whole thing out (I-pipe --> back).
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Kaweh
Aug 9, 2015 02:54 PM
