tpi 5,7 hp
Old Nov 23, 2005 | 01:49 PM
halli's Avatar
Car: trans am gta 1989
Engine: tpi 350 5,7
tpi 5,7 hp
i have 1989 5,7 trans am gta what is the horsepower orginal Thanks Halli
Old Nov 23, 2005 | 03:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
click tech data on the main menu.
Old Nov 23, 2005 | 07:42 PM
bonz's Avatar
Car: 89 GTA
I was wondering. The numbers in the tech data, are those rear wheel horse or is that at the flywheel. It doesnt say.
THANKS
Old Nov 23, 2005 | 07:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Single cat version had 225 HP at the motor. The dual cat version had 235 HP at the motor. Hope this helps.
Old Nov 24, 2005 | 04:19 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
in 1989 I heard from other sites ..... it was 245 for the L-98 .
Old Nov 24, 2005 | 04:35 PM
Car: 1989 GTA
Engine: 369 TPI
He has a 1989 Trans Am GTA.
Old Nov 24, 2005 | 05:49 PM
halli's Avatar
Engine: tpi 350 5,7
thanks
Old Nov 25, 2005 | 11:27 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Quoted Hp by a vehicle manufacturer is always flywheel Hp. The Hp values listed in the tech data are the GM Hp declared Hps. I think that since the flywheel Hp is always higher (impressive) than the actual Hp delivered to the rear wheels, that is why the manufacterer lists the flywheel Hp.
If a magazine or a owner of the vehicle puts the car on a chassis dyno, then (of course) you have the actual Hp delivered to the rear wheels, usually shown as RWHp.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
