which intake for 113's
Old Dec 5, 2005 | 08:33 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
I am rebuilding my engine and I have a good deal on 113 heads with .550 lift. which intake,cam would you use with this setup? hsr, super ram or longtube, cam lt4 hotcam? thanks for any help.
Old May 9, 2008 | 09:01 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Re: which intake for 113's
So how did you make out?
Old May 11, 2008 | 09:22 PM
jacque_strap's Avatar
I have a pair of 113's I am using for my 383 build. They have been machined to flow pretty much as good as they will ever get. I put them on the flow bench and then put the stock intake system on the flow bench as well. The stock TPI set-up out flowed the 113's. Take this for what it's worth. I'm not saying the HSR is a bad idea, but it certainly isn't cheap. If you are going to get into PROM tuning, the stock TPI might work just fine with the right tweaking.
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
