mounting hardware
Old Dec 6, 2005 | 10:00 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
mounting hardware
Hi
I am converting carb to tpi. What brackets will I need that were not originally on the carb set up? . . . .Remote coil? Throttle cable? TV cable? pump and filter mounts? etc. . .
Where can I get these?
thx
Jeff
Old Dec 7, 2005 | 10:28 AM
Vader's Avatar
What year TPI system? Is this going into a Chevy or Pontiac? Some of the support devices are different, like the MAF brackets and ducting on older TPIs.
Old Dec 7, 2005 | 08:56 PM
jjlabinski's Avatar
Engine: shinny 350
TPI is 86 car is 84 pontiac
Old Dec 7, 2005 | 09:46 PM
Shagwell's Avatar
Car: projects.......
mainly, make sure you get everything from donner car. The brackets and hard ware from a TPI are different from carb stuff. - mostly what you mentioned, cable bracket(cable lengths), coil mount, fuel lines, intake(filter ducting), and the general stuff like wiring harness, computer,etc...
Bohemian
Aug 15, 2017 05:11 PM
Deemax
Sep 12, 2015 06:53 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
