TPI won't start after head gasket job
Old Dec 7, 2005 | 11:42 AM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
the fuel pump runs for 15 seconds or more after trying to start, and i can hear fuel sloshing around in the fuel rails, is the fuel rail not staying full for some reason? are there any tricks for starting after having fuel system apart to get injectors cleaned? also my dist plug-in (the large one) is so tight i can't turn it counterclockwise at all, is it in wrong?
Old Dec 7, 2005 | 12:57 PM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
IMO, I would tend to believe that your dist is in wrong. If it were me I wouold pull it, bring the # 1 cyl to TDC on the compr. stroke and drop it back in with the rotor btn pointin towards #1. It "SHOULD" fire up then and then you can adj your timmin accordingly.
Old Dec 7, 2005 | 01:49 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Have you adjusted the valves properly. I did that mistake once and i didnt start because some of the valves where open at the wrong time.
Old Dec 7, 2005 | 09:37 PM
Shagwell's Avatar
Car: projects.......
not opening at the wrong time, just staying open to long/continously... as stated check for TDC/dist. setting, and check valve setting...
Brcharrelson
Aug 26, 2015 07:47 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
