runner question
Old Dec 9, 2005 | 02:32 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
runner question
i am looking into new runners for my 305 TPI. but i was wondering if they are going to flow any better than what i have.
the ones i'm lookin' at are the corvette L98 runners, and i have an LB9
any increase in flow expected?
Old Dec 9, 2005 | 05:36 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
nope as far as i know all TPI intakes be it 305 or 350 flowed the same. Some older TPI's had the ninth injector intergrated in the runner.
Old Dec 9, 2005 | 05:39 PM
Shagwell's Avatar
Car: projects.......
nope... they're all the same...have you ported your plenum? - needs to be done before you go to runners other than stock...
Old Dec 9, 2005 | 07:24 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
They will give you a few ponies just bolted on, to see a decent gain, youll need to port you plenum. The runners are really ment for 350 car, but it should bump up the power band on you 305, not neccessarily more power, but it should allow it to rev 200~rpm higher, which every tpi needs.
btw, don't i see you on iroczone.com?
Old Dec 9, 2005 | 07:51 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
You're a moron. Stock runners are stock - 305 or 350, they were the same on both engines.
Old Dec 9, 2005 | 07:52 PM
BlueZee28's Avatar
yup that's me on iroczone as Th3rdGen On ZR1s...and yea i should probably port the plenums first, i thought about that and didn't think anything of it...
Old Dec 9, 2005 | 08:00 PM
305 arent starved for air like 350s are. Thats why the runners came out, they were intended for bigger cubed engines.
Old Dec 9, 2005 | 08:07 PM
BlueZee28's Avatar
i'll probably hold off until summer so i just buy some already-ported SLP plenums to go with it
Old Dec 9, 2005 | 09:40 PM
GOY's Avatar
GOY
Why what runners came out? He asked if the L98 runners are different than LB9 runners - they are not!!! L98 and LB9 runners are the same, period! The whole intake (minus injectors) is the same year for year, the plenum, runners, baseplate and throttle body. The only diference was the 'Vette baseplate with ext. egr.
In no post, other than the very last, did he mention a non-factory runner. He said he was looking for runners, but the L98 runners. You went on to state that he would see gains. Maybe you misunderstood which runners he was asking about when he asked "the ones i'm lookin' at are the corvette L98 runners, and i have an LB9 any increase in flow expected?"
Old Dec 9, 2005 | 10:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
GOY is 100% correct. Same size runners regardless of 305 or 350.
Old Dec 9, 2005 | 10:29 PM
BlueZee28's Avatar
thanks for the help guys!
tazs2000
Jul 15, 2017 08:44 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
redmaroz
Aug 16, 2015 11:40 PM
