Rattling at a roll
Old Dec 9, 2005 | 07:33 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Rattling at a roll
Ive noticed when I roll about 3-6 mph, under my car somewhere, there sounds like there are rocks in a coffee can jingling around. Im thinking its a bad cat, but does anyone know what could cause this?
Old Dec 9, 2005 | 08:34 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
rocks in a hub cap/beauty rim, backing plate, brake drum, stone in tire(s), or something simple (I hope).
Old Dec 18, 2005 | 07:22 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I had a problem in the past on a different 92 Z28 then what I currently have, when I put the sub-frame connectors on, the garage who installed them put them right up against the exhaust...at a slow roll i noticed what sounded to be a lifter knock..or something of the sort. What it turned out to be was "Block chatter" cuz the vibration of the motor running was connected to the exhaust which was bumped right against the subframe which was then transferred throughout the whole car. Obviously at higher speeds I wouldn't have noticed it. After I re-routed my exhaust away form the connector, noise went away. Somethin to look at.
Old Dec 18, 2005 | 07:45 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Hit your cat a few times and see if you hear it.
Old Dec 18, 2005 | 08:10 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Yep you'll just need to get under it and do a little banging and touching of differnt parts. Try to narow down location before getting dirty.
This might be way off the bat but Check your torque converter bolts make sure they didn't snap off and rattleing around. I've had some extreme shift kits it the past which snapped my bolt heads.
Old Dec 21, 2005 | 06:57 PM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
I had that problem with my 84 z28.. the heat shield of the cat would rust off a lil bit, and it would rattle a lil bit
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
FormulaEngland
Sep 30, 2015 01:50 PM
