Code 43 w/new motor
Old Dec 13, 2005 | 11:48 PM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
Code 43 w/new motor
Last week I lost oil pressure on my 1991 tpi 305 knock knock knock....... Well I went ahead and installed one of my spare motors another 305 same cams same everything. With it I did some mild port work on the heads ported my upper plenum to match my slp runners and added a set of 22lb. injectors. The motor started right up and I instantly had an eng. light come on. pulled the codes and came up with a code 43 which has something to do with the esc system. Went ahead and installed a new knock sensor but still have the same code. Timing is dead on at 8*. I did notice that the computer is constanly adjusting the timing at idle it seems to constantly hunt picking up and dropping about 100 rpm every 30 secs or so. what else should I check. In field service mode it goes into closed loop when the temp comes up. Would the bigger injectors cause that code???? It doesn't seem to be running rich in fact it seems to have less exaust smell than the other motor. what else should I check?????
Old Dec 14, 2005 | 08:24 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
change that knock sensor...fixed my code 43
Old Dec 14, 2005 | 09:53 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
need to check the wire going to that knock sensor, key on, 4-6 volts. you mighta' snagged that wire or something. happened to me, too, on my rebuild...
Old Dec 15, 2005 | 12:01 AM
mcwpns's Avatar
May have found the problem. Pulled the cap and rotor off and found the hall effect plate to be loose/broke. I know it should rotate a couple of degrees but this one moves up and down also. Checked another distributor and the other doesn't move like that. Hoping that might be it. Checked the knock sensor wire and had reference voltage and already replaced the sensor so hopefully its in the distributor.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
blackd-out z28
Aug 15, 2015 08:18 PM
