Will 3Will I blow up my 305 headed 350 with 350 chip and L98 injectors?
Old Dec 14, 2005 | 10:49 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Because I won't put them in if that's what is going to happen. I got the 350 memcal and injectors waiting for me, but I don't want any; and by any I mean ZERO, ZILCH, NADA, adverse affects from installing it. Will I have problems with the 305 heads on there with 350 tables?
Now here's a question for future chip burning, the tables for a few were different for the 305 because of the heads it has, in the future should I change those values to 305 specs or will it not even matter?
Thanks guys!
Old Dec 14, 2005 | 12:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
no and yes
Old Dec 14, 2005 | 03:11 PM
Car: 1994 Trans Am
So, no it won't blow up.
And Yes it won't matter or yes change the values?
Old Dec 14, 2005 | 03:56 PM
Z69's Avatar
Z69
In most circumstances, you do not want to use 305 values.
Make sure to run the 350 KS too. The memcal/KS are tuned to each other.
Old Dec 14, 2005 | 11:46 PM
Car: 1994 Trans Am
Well, I'm pretty sure the block has the 350 KS, but I will check to be sure beforehand.
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
