gasket question
Old Dec 14, 2005 | 08:00 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
gasket question
That plate in which the iac sits in..on the bottom of the throttle body...what is that called. Im putting my stock tb back on and i need that gasket so i can take off all my stuff off the holley and transfer it back onto the stock tb. I got stainless bolts from tpiparts.net and they called it a coolant plate?
Old Dec 14, 2005 | 08:59 PM
Shagwell's Avatar
Car: projects.......
they called it a coolant plate because(if yours is still hooked up) coolant loops out of the intake base and goes through that plate, then over to your heater valve. Warms the air going in. Some people claim its a good thing, most claim its bad. - But yes "coolant plate" would make sense.
Old Dec 14, 2005 | 09:22 PM
Car: 1991 Z28
Engine: SBC
i was searching advance's site and i couldn't find the gasket if i called it a "coolant plate"....any ideas?
Old Dec 14, 2005 | 09:25 PM
Shagwell's Avatar
advance/autozone/etc should be able to get you a throttle body gasket kit pretty cheap. - I use to have the AZ pn for it when i worked there...then you'll have all new gaskets...
Old Dec 15, 2005 | 11:03 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The gasket for the IAC housing is included in GP-Sorenson's 963008 throttle body gasket kit.
HTH
Old Dec 16, 2005 | 12:01 PM
Shagwell's Avatar
ahhhh, there's that kit number...
Old Dec 18, 2005 | 06:45 PM
Car: 1991 Z28
Engine: SBC
got all the gaskets..thanks guys
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
