Ported Tpi And Sdpc Intake Or Lt1 Set Up
Old Dec 20, 2005 | 09:39 AM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
Axle/Gears: 3:27 posi
I am entertaining the option of getting a LT1 intake set up to replace my TPI set up which consist of SDPC vortec heads and intake with ported plenum. I am wondering if i would get more power with the LT1 set up. Also, if i go LT1, do i have to go to speed density and change wiring or can i keep the MAF and do i have to change heads also or would a LT1 bolt on my vortec heads. I just want to know if it would be worth it to change or just keep what i got. thanks
Old Dec 20, 2005 | 11:20 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
With the LT1 setup you will have to have the manifold machined for the distributor.
Old Dec 20, 2005 | 11:29 AM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
i was going to buy intake to match. I was thinking of pulling my SDPC intake of with the plenum and runners and buy a new intake for LT1. I have less than 5000 miles on new set up shown on my sig but have been told to go with LT1 to get more power. I know i will lose some torque by switching (which i dont like because i love my torque) but is it really worth the switch as far as 1/4 mile times to do the switch.
Old Dec 20, 2005 | 05:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You would be better off having a LT-4 intake modifed (LT-4 intake ports better match the intake ports on vortec heads than the LT-1's ports). Or, get the vortec stealth-ram.
However, a good set of runners and a decent cam will get you where you want to go.
Just my
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
Jake_92RS
Aug 11, 2015 10:39 AM
