cold air induction question
Old Dec 30, 2005 | 10:22 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I've noticed some posts in which people have said that some people dont have MAF's. Does this mean they have MAP's or does it mean they have nothing altogether. If it is indeed the latter, does it affect the air flow to the engine a lot if i were to take out the MAF sensor. I say this because I cannot think of a reasonable way to make a cold air induction without disturbing the operations of the MAF sensor. I've noticed that some people have air filters mounted directly onto the throttle body. What are the advantages and disadvantages to doing this.
Old Dec 31, 2005 | 01:43 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Either one has a MAF equipped engine management system or a speed density(MAP) equipped system. Only those with speed density systems can have air filters directly on the Throttle Body. Your car will run like crap if you take out the MAF sensor.
What you may be thinking of is "De-screening" the MAF sensor, in case you haven't noticed(sorry if I'm being a dick) there are screens attached to the MAF sensor that can be removed. Research on this topic would lead you to believe that doing so is dumb which is probably the truth.
The End.
Old Jan 1, 2006 | 01:09 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
you will gain 100 hp by removing the maf..
then you should race me for some cash...
Old Jan 1, 2006 | 07:13 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
haha that's funny. No really that's funny.
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
