TRICKFLOW owners with heavy port jobs...
Old Jan 1, 2006 | 12:29 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Any flow numbers, with new port CC measurements and mod (to the head/valve) descriptions.
Not interested in stock numbers - just curious to see how far some people are taking these heads, as it seems a lot of people are running them.
Old Jan 1, 2006 | 06:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
With a clean up on the intake our local porter is getting around 265CFM. On the exhaust he is opening them up and getting past the 200cfm mark. This is a 75% I/E ratio. I'm going this route on my heads during the next build up. I will post the actual flow numbers when I get them.
Old Jan 1, 2006 | 06:52 PM
GOY's Avatar
GOY
That exhaust figure is impressive......
Old Jan 1, 2006 | 09:18 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I had my 195 Trick flows CNC ported by Total engine airflow and I cannot remember every number but I do remember the higer numbers. At .600 lift 309/240 at .650 lift 311/250. The low lift numbers were also very impressive but I cannot rember the exact numbers. Run a search I did post all the numbers about 3 month ago.
The runners ended up at 218cc after porting and I had 2.08/1.60 valves.
As far as I am concerned the trickflow heads are have lots of potential.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
