what cam for vortech heads and custom chip
Old Jan 2, 2006 | 03:49 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
im looking for a hyd. roller cam for a 355 with vortech heads and base, stock plenum, runners, and throttlebody, 9-9.5:1 c.r.,
if needed, i will have a chip burned by FASTchip or someone to the specs.
my converetr is a holeshot 2400(which i only get about 1800 against the brakes, and maybe 2100 flash stall.)
also, i would use a hyd. flat tappet cam if theres one that suits this particular setup well.
thanks for any advice
Old Jan 2, 2006 | 09:48 PM
Shagwell's Avatar
Car: projects.......
first off, save yourself and don't go flat-tappet. - stick w/ the roller. - secondly, no mail-order chip can be burned perfectly for any cam. The chip doesn't know/compensate for cam size. - now the goods. If you're sticking w/ a stock base, runners, and plenum w/o any major porting, look for something around 210-220 duration(no more) and around 480 lift. You'll want around a 112 centerline for an efi car. unless you try to go larger than this(pointless w/ stock LTR components) you shouldn't really have any major problems w/ a stock chip/tune. - It won;t be ideal, but it'll work...
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
djmarch
Aug 19, 2015 12:07 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
