fuel pump, anyone?
Old Jan 9, 2006 | 11:18 AM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
fuel pump, anyone?
O.k., so today i am driving to work and my car just shuts down and i am trying to pull over with no power accessories at all on the highway! I just changed my cap and rotor on the dist. and drove it around for about 5-6 miles after the install. i do not know if it is possible for anything to be wrong there. i know that the fuel pump is probably the original and i have 140,000 on the odom. The car acts like it can turn over when i try to start the engine but no luck. i might have to check the fuel pressure. i can hear the pump relay kick on before starting. can everyone that reads this give some really good info and advice?
Old Jan 9, 2006 | 11:32 AM
OneGravenKiss's Avatar
Car: 1986 WS6 Pontiac Trans Am
Re: fuel pump, anyone?
mine did the same thing and it was the fuel pump,try sticking a wire in the E terminal that has 12 volts running to it i believe if memory serves me right and that should kick on the fuel pump with out having to try to crank her up and if u dont hear the fuel pump kick on then its fried. Grab a book as well SEE YA!!!
Old Jan 18, 2006 | 08:18 AM
Car: 85 Z28
Engine: 305 LB9 TPI
anyone else have this problem?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
