Important Tpi Question Please Help
Old Jan 10, 2006 | 01:36 PM
IROC4U's Avatar
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
i have 2 camaros both Irocs one is quadrojet i am converting it to TPI i am changing all the wires and the rear only the Tpi iroc is automatic and the other iroc is manuel the rear end is going to be changed its a 2:73 rear on the tpi iroc with 145 speedo ...........will i run into any problems concerning the prom or computer please help thank you email me Remanufactured086@hotmail.com or pm me
Old Jan 15, 2006 | 11:52 AM
Vader's Avatar
The carbureted engine car will require a different ECM and PROM/MEMCAL. The TPI car should not require any calibration change, so long as you select the correct gears for the speedometer drive so the VSS outputs 4,000 pulses per mile.
Old Jan 15, 2006 | 09:43 PM
Shagwell's Avatar
Car: projects.......
- sorry this is kinda off topic - Vader, how do you figure out the amount of pulses you need for a speedo? as in my 85 mph speedo(in my blazer) is 15mph off...
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Ozz1967
Aug 16, 2015 10:23 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
