Maf Sensor
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
Maf Sensor
i was wondering if there is anything i can do to get rid of my MAF sensor?? i tried just taking it off and my car dies out.... is there anything i can do to get rid of it? or am i stuck with it? i wanna put a Cold Air Intake Tube Direct From the Throttle Body.... and get rid of it...
Car: 88 IROC Z28
Engine: L98 350
Axle/Gears: 3:27 posi
keep the maf. just get the cold air intake from hawks third gen. great system yet a little pricy but by the time and money you spend on converting to speed density, you could just get the other almost.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Keep the MAF, and as suggested above get the "ram air boxes" from Hawks third gen. I have a similar setup, but a molded plastic air box as one complete, drop in unit. I removed the fog lamps on my IROCZ and removed the factory plastic stuff under the air filters, along with the upper tray. What I purchased brings in cold air thru the empty fog lamp locations, turns the air 90 degrees upeards , directly into the bottom of the air filters.
In fact, you can make your own "tunnels" yourself. Do a search on this wen site, you will find stuff on this matter.
The company that I purchased this ram air piece is out of business, so I probably have one of the few in this country.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Here is a picture of my cold air intake with the MAF. Made 322 rear wheel horsepower with it.
Car: '87 IROCZ
Engine: 395 ZZ4
That is a very nice cold air intake setup, but I am talking about a true cold Ram air setup. For a Camaro, you cant beat this system.
Car: 1989 GTA
Engine: 369 TPI
Got it from work. We were cleaning out a storage facility we had and there it was. It is a piece of 4" hump hose. Do a internet search. Here is a picture after the conversion to MAP. Going to the dyno next weekend. Hope to be up around 330RWHP. I will post the results.
- you can't loose the MAF unless you change computers. bottom line. - my 89 stock set-up was the same as the SLP cold air kit. - pretty good set-up. - not as nice as 1989GTATransAm's set up, but a nice piece...
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
