ok guys last attempt!!!!
Old Jan 10, 2006 | 05:10 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
ok guys im just about ready to give up and take her to a mechanic but before i do that im going to give it one more shot!My 1990 IROC Z, (305 TPI) is giving me some problems. i go to turn her on and the instrument panel turns on but i get nothing from the starter? i know the starter is good, so what should i check? i hear the gas pump prime for a couple seconds and a click in the vacuum. also the security light on the panel remains on...does this mean anything? but no starter? please help me and be as specific as possible as to what to check and where it is located please thankyou guys so much!
Old Jan 10, 2006 | 05:39 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I say it is either a fusable link or something to do with vats. Did you check your starter enabler relay?
Old Jan 10, 2006 | 05:46 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Have you checked the battery? It's probably the VATS like everyone says,
but better start with the basics.....
Old Jan 10, 2006 | 06:03 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
does the security light come on when you try to start? if not, then the fine wire that goes to the lock cylinder are most likely broke. you can bypass it by mesuring the resistance on the key (black pelet) and soldering a resister (within 10% resistance of the key) onto the wires that go to the plug (small plug with white wires wraped in orange cover), but be sure to solder onto the car side of the harness and unplug the steering column side.
good luck
Old Jan 10, 2006 | 06:12 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
I would suspect the VATS, my 91 Z28 does the same thing and it will take a few R&R of the key to get it to start. I've just been too lazy to fix the key or bypass the system. Try R&Ring the key and see if anything changes.
Old Jan 10, 2006 | 06:49 PM
2badcams's Avatar
where is this relay at? on the starter? someone told me to check the ignition switch? does anyone know where it is? or also the neutral safety switch but i dont know where neither of these switches are nor the starter relay? any help? so i can check them?
Old Jan 11, 2006 | 12:01 AM
Dirtbik3r's Avatar
Maybe this will help... Actually, I forget where it is... lol
Old Jan 11, 2006 | 07:41 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
your starter enabler relay is behind the left(drivers side) kick panel. there is a fat green wire and there is a fat yellow wire. put a fused jumper between these two terminals.
move your collum if it is tilt up and down the broken wires in the collumn may make contact so have the key forward when you move the collumn.
I think I told you to buy the helms manual. I has all the diagnostic info you need. You could take the whole car apart and put it back together with it. All you need is the ability to read and comprehend.
Do not take it personally I tell everyone "HELMS MANUAL"!!!
Old Jan 12, 2006 | 07:59 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
stater wiring
have you checked the starter wiring?
take a test light and hook it up to the small wire( purple i think) and have someone try to start the car. with the key in the start position the light should light up ( If it does needs a new starter) If it don't start checking the VATs and or starter relay. Also have you checked the fuses? i know there is a fuse labeled crank and VATS check those also.
Also check where the loctaion of that Small wire is mounted on the starter. It should be located on the pin closetest to the engine block.
and hell for ****s and giggles hook a hot wire up to the small wire and put power on it and it should turn the motor over.
Old Jan 14, 2006 | 09:06 AM
jamon8's Avatar
Engine: 350 tpi
I tell you what grab the easy button and press it because we gave you all types of good advise each time and it is going to take more than just replacing a vaccumn hose.
Maybe you need to take it to a mechanic and let the people you are really trying to fix there cars have the space.
did you just want to sound good when you went to talk to the mechanic?
Old Jan 17, 2006 | 06:13 PM
2badcams's Avatar
hey guys...
thanks for all your help... heres whats new. well the car still wont start, i replaced the neutral safety switch, and also connected a resistor in between the two cables for the vats system and it works because the security light goes of when i turn the key. the problem still remains though....no cranking at the starter? what else should i check?
Old Jan 17, 2006 | 06:15 PM
Shagwell's Avatar
Car: projects.......
you need to start checking w/ a test light and follow the wire to the starter. You need to see where you have power and where you don't.
Old Jan 17, 2006 | 11:05 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
Re: stater wiring
try this.........
midge54
Sep 2, 2020 07:13 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
gwade12
Aug 8, 2015 08:17 AM
