Breaking her in
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Breaking her in
Hey, just jotting down the procedure i'm going to use to break in my new 350. Please add or edit to this or post your own methods.
1. Before starting, set TPS to 1/2v and jumper IAC pins on aldl.
2. Crank it over and turn distributer to get a estimated smooth idle.
3. Run for 30min revving from 2-2500rpms. (Breaks in cam lobes and lifters)
4. After that 30min has been completed, immediatly set the correct timing with a timing light.
5. Turn off and let cool.
6. Drive for 30 miles varying loads speeds while not exceding 5k and using lots of throttle.
7. After 30 miles, run 5 med throttle accelerations to 60mph - coast back to about 20.
8. Nextly (during same trip), run 5 full throttle accelerations to 60mph - coast back to about 20.
9. Change oil and filter
10. Drive for 500 miles not beating on the car.
11. Change oil and filter again.
This sound right?
This sound right?
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
if it is a roller cam you should be alright with only 10-15 min of 2500rpm, and that is more to break in the punched out cylinders.
good luck
good luck
UltRoadWarrior9
Apr 28, 2020 10:39 PM
sjorgens
Oct 1, 2015 07:54 PM
