crappy idle problem
Old Jan 11, 2006 | 10:21 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
crappy idle problem
Ok, I've having some wierd problems.
I got an L98, on cold start-up, it acts more like a carbed engine, I have to feather the gas to keep it running. Once warmed up, it runs kinda rough, espeacially under load. No misses, just kinda rough. I have good fuel pressure, sitting on 45-48 i belive. its a speed density car if that helps any. thanks for the suggestions.
Kyle
Old Jan 12, 2006 | 01:46 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I've got an update. The car threw a code 32, which is the EGR valve. Does that sound like the symptoms i described?
Also, could it lead to problems if i choose to just block off the valve?
thanks,
Kyle
Old Jan 12, 2006 | 10:34 AM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
Axle/Gears: 3:27 posi
if you block off the egr valve, you need to have it deleted from the ecm.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
