cold start block off?
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
how would i go about blocking the cold start injector?? i found some cheap slp runners but they are for 89-92 and mine is an 88. can i just unscrew the injector line from the fuel rail and plug it?? if so does anyone know what size the plug would have to be?? thanks alot
joe
joe
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
The plug needs to be o-ringed. There is a shop that makes the plugs for fuel rail & cold start injector hole. Or you could filnd a fuel rail for a later model car 89-92.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
and check the following link:
