How far can stock ignition go?
Old Jan 13, 2006 | 12:53 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
My list of things to do is as follows......
MiniRam I & fuel rail
58mm TB
24# Fuel Injectors
Bosch TPIS Fuel Pump
4.10 Gears
ZZ-X TPIS camshaft
Trickflow T.W. G2 heads w/heavy springs
67cc chamber
Most of the parts I already have, but was wondering when I complete my set-up, should I add an MSD ignition and coil? Or would stock be good enough? I know it sounds like a silly question to buy all this high expense stuff, then leave that one item stock, but after buying all this, money is kinda limited. Maybe I can just keep it stock for the time being til I get money? Thanks for your input.
Old Jan 13, 2006 | 01:12 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Id go with the msd. When you build an engine you should try to get rid of all the weak links. Not a big deal though if your on a budget the stock one should get you by, but msd would be better of course.
Old Jan 13, 2006 | 01:14 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
MSD for sure...the oe dist, assuming it's factory fresh (which ours aren't), are
only good to 5,500.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bryan F
Aug 18, 2015 02:28 PM
