code 32
Old Jan 20, 2006 | 04:17 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
code 32
i threw a code today and it came out to be code 32, baro circuit sensor, can anyone lead me in the right direction to fix this? ive never even heard of it. what does the baro sensor do? thanks in advance
Old Jan 20, 2006 | 04:29 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Just a FYI -
code 32 can mean more than the baro sensor...
"32 Barometric Pressure (BARO) Sensor circuit failure
OR Exhaust Gas Recirculation (EGR) valve diagnostic switch - closed during engine startup or open when EGR flow requested by ECM
OR EGR / EVRV (Electronic Vacuum Regulator Valve) "
- taken from http://www.tradervar.com/GM_Codes.htm
Hope this helps!
Old Jan 20, 2006 | 05:12 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
my service manual says code 32 = "EGR SYSTEM FALURE" for the 5.0 and 5.7
there are two pages of diagnostics for it. i am not going to type them all out. but perhaps somone with a scanner will scan em in for you. or you could buy the book. best $35 i ever spent.
Old Jan 20, 2006 | 11:43 PM
Car: 89 Formula
Engine: 5.7 TPI
ok thanks for the help. i havent had EGR for almost a year now, i would be surprised if thats the cause. i guess ill put a scanner on it tomorrow and find out what the real problem is.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
