Need new vacuum lines...
Old Jan 20, 2006 | 09:03 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Hello TPI-freaks,
I need some new vacuum lines of the TPI.
see the pics..
and i need also a hose, mine is broken..
where can i order these parts ?
see blue arrows..
Old Jan 20, 2006 | 09:49 PM
Vader's Avatar
Rubber vacuum hose and semi-rigid nylon line can be found at almost any well-stocked parts store. The larger PCV vent tube in your first photo may be a bit more difficult.
Old Jan 20, 2006 | 10:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I noticed two Autozone's I went to didn't have it, but Advance Auto Parts did. Not sure what's available in your area but its certainly cheap enough if you find it.
Old Jan 20, 2006 | 10:33 PM
GTA89's Avatar
Engine: 5.7 350
thanks friends !
i will try...
the problem is i don't live in the USA,
so this is hard to find for me...
that's why i wanted a site like ebay.com so that i can order it,
and that they could send me the parts..
but if Vader saying that its almost available anywhere
then i should check again in my area...
Old Jan 21, 2006 | 09:02 AM
Vader's Avatar
The hard nylon line used for the FPR and EGR can be 4.5mm. The rubber hose used for those should be about the same.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
