Code 44
Old Jan 26, 2006 | 08:32 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Code 44
My car keeps flashing a code 44 after about 10 minutes of driving. It does it in all conditions, so I have a constant problem. I'm running too lean. What could cause this? Obviously a bad 02 sensor, but has anyone else encountered this problem and changed something else to fix it?
Old Jan 27, 2006 | 06:09 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
I dont know. Did you check the owners manual? That usually helps.
Old Jan 27, 2006 | 07:36 PM
ontarioiroc's Avatar
Car: 90 IROC-Z
O2 sensor, left bank is running lean.
Old Jan 28, 2006 | 07:42 AM
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
When I had a code 44 it ended up being the ecm.
One way to tell, is to pull the o2 sensor. If there's a black carbon build up on the o2 sensor the car is running rich.
Thus, the ecm has failed. The ecm thinks the car is lean so, it keeps pumping more gas in to the engine, creating the extra carbon on the o2 sensor.
hope this helps
By the way, it takes 10 mins, to show the code because the car doesn't go into closed loop untill it gets warmed up.
Old Jan 28, 2006 | 10:15 AM
Vader's Avatar
There are numerous reasons for a '44' to be present. The most obvious is the O² sensor getting old and weak (typical failure mode). If the sensor is good, there are still plenty of things to go wrong that will cause the code.
Exhaust manifold leakage, AIR diverter valve or distribution tube problems, low fuel pressure, vacuum leaks (just about anywhere), poor electical connections at the O² sensor and/or ECM, failing ECM (poor bias voltage), clogging injectors, incorrect PROM/MEMCAL, and a host of others.
You can search the archives for "code 44" and find about eleventy-jillion threads. You are not alone.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
