Super Rams
Old Jan 30, 2006 | 08:48 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Super Rams
What is the difference between these two Super Rams? And what is the difference in the HP range?
Type in part # acc-74196
Old Jan 30, 2006 | 10:17 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Looks like one of them comes machines for a mono-blade throttle-body, compared to the 58mm dual-blade unit.
Old Jan 30, 2006 | 10:44 PM
VincentZ28's Avatar
If you look at them again, one is slimmer than the other. I bought the slimmer one in 1997. At the time I didn't know their was 2 different Super Rams.
Old Jan 30, 2006 | 11:33 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
If you check the application chart for the ACC-74198F on Summit's site, you will see that it's for a LT1.
So yes, it does have the shorter plenum height to clear the lower hoodline on the 4th gens.
Accel must have decided that there was enough of a need to start producing the LT1 version again. I believe the mono-blade throttlebody port opening is new to the design though.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
