Quick Question on Intake Removal........About Radiator Coolant
Old Jan 31, 2006 | 02:07 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Im cleaning and painting eveything from the intake up on my car. I removed everything from the intake the last couple of days and the last thing to do is take the intake off but there is coolant still in the intake.
I took the radiator hose off the front of the intake and let the coolant drain and then took the elbow and thermostat off and I noticed the coolant is still in the intake.
Is it safe to remove the intake with the coolant still in it and is there anything to watch for?
THX
Old Jan 31, 2006 | 02:54 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
DO yourself a favor and remove as much coolant as posibble from all areas before yo remove your intake. You do not want any coolant in the bottom end.
I had a small amount fall in the bottom , where the cam bearings are and if caused a scuffed bearing even after I drained and re-filled with fresh oil.
Admitting my stupidity so you don't have to chance anything. Treat an open engine like it's open heart surgery in a figurative since.
.02
Old Jan 31, 2006 | 02:57 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Remove the bottom hose on the waterpump and that should take care of it.
Old Jan 31, 2006 | 03:22 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Pull out the block drain plugs, middel of block (both sides) just above the oil pan rail.
1- pass side knock sen.
2- driver side plug ( just like oil drain plug)
That will drain your block & intake.
joe
Old Jan 31, 2006 | 03:34 PM
gotmilf's Avatar
Car: 84 Z28, Silverado 2500HD
Engine: 5.0
Transmission: t-5
When I changed my intake, I pulled the lower radiator hose, seemed to empty the motor very well. I let the car sit for a day before removing intake. No coolant left.
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
