starter wiring
Old Feb 2, 2006 | 06:19 PM
bonz's Avatar
Car: 89 GTA
starter wiring
I toook out my starter to put a new one in and forgot the wiring. Does the large black wire and the group of 3 orange wires connect to the large post in the middle of the silanoid. There are 2 small posts on the silanoid on each side, which post does the purple wire connect to or does it matter. Hoping to get it started tonight so any help would be great.
THANKS
Old Feb 2, 2006 | 07:24 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the wires with the big eyes all go to the same terminal, it will be the big terminal away from the starter motor at the top of the solenoid.
the purple wire goes to the small terminal thats the closest to the engine, i believe its marked with a "S" on the solenoid, if its hooked up to the wrong terminal it won't crank when you hit the key.
Old Feb 2, 2006 | 07:38 PM
bonz's Avatar
Car: 89 GTA
Thanks a lot. You saved me some time.
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
