MAF or MAP sensor
Old Feb 7, 2006 | 04:29 PM
john_p_50220's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1
Transmission: AT
MAF or MAP sensor
I just bought a 1991 Firebird and just put in a fuel injector rail, all new injectors, and a new fuel pump. When I push on the gas to take off from a stop at a decent rate or try to accelerate faster there is a popping noise, it isnt loud like a backfire and you cant feel it. Could this be a MAP or MAF sensor or more? Only thing I can think of would be exhaust or catalytic converter but I dont think thats the problem. The popping isnt loud like a backfire but more muffled like and I can feel it through my accelerator pedal.
Old Feb 7, 2006 | 05:21 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Did you change spark plugs and wires yet?
Old Feb 7, 2006 | 06:29 PM
Shagwell's Avatar
Car: projects.......
It is either a MAP or MAF, car won't have both. 91 should be speed density(MAP). - sounds more like ignition to me. plugs/wires maybe timing advanced to far/module acting up...
Old Feb 10, 2006 | 08:56 AM
Engine: 3.1
Transmission: AT
Thanks for the reply guys, better and faster than other forums I've tried. Though I did find the problem...it was the exhaust manifold gaskets and a broken exhaust manifold bolt.
BumpaD82
Feb 26, 2016 02:57 PM
customblackbird
Oct 1, 2015 04:30 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
