timing
Old Feb 12, 2006 | 09:32 PM
graphicideas1's Avatar
timing
with the timing wire unplugged - should my timing move as i rev the engine? to set timing i am disconnecting timing plug & setting time but if i rev engie it changes
Old Feb 13, 2006 | 02:56 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Base is set at 6 degree(if TPI engine).
With EST unhooked u should notice a 2-4(I think its 2 degree) degree change in timing if you rev it past around 1600rpm or so.
This is built into the module.
Some searching will yield more explanations
Like I said this is built into the module kind of like a fail safe so at higher rpm's it does add a slight amount fo timing.
Anymore than a few degrees or a constant state of timing jumping with the EST dosconnected, I would have to say you have an ignition issue or timing chain issue/spark scatter.
later
Jeremy
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
