305 cam ?
Old Feb 13, 2006 | 11:38 PM
StephenGTA's Avatar
Car: 89 TA, 97 TA
Engine: TT350,S/C 383
305 cam ?
i bought my g-friend an 86 305 tpi iroc an she wants her car to have a somewhat choppy idle i found this cam its the comp cam cl12-209-2 will it work in this car with of course some cp tuning spec on the cam are. Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 229
Duration at 050 inch Lift: 219 int./229 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 277
Advertised Duration: 275 int./277 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.462
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.482
Valve Lift with Factory Rocker Arm Ratio: 0.462 int./0.482 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in):
If not please help me out the car needs to still run good but have that agressive idle.
Old Feb 14, 2006 | 12:38 AM
91Z28-350's Avatar
Picking a cam for the sound? All show, no go? LOL!
Take any cam and have it ground on a small LSA. Big overlap is what you're looking for.
That cam will have an idle. Good size cam for a 305, way too big for a stock car. It'll probably run like crap, IMHO. It'll work, it's just a mismatch for a stock car. No exhaust work, no heads, no intake work? What are you working with?
Find out what else she wants besides a choppy idle. Pick a cam to match your components with a target in mind...other than sound.
Old Feb 14, 2006 | 04:44 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
yeh i dont know much about cams but by the specs on that it seems like its a lil to much of a cam . and with stock heads itll be a waist of cam.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
