New to the wold of Horse Power?
Old Feb 14, 2006 | 02:25 PM
tito63nova's Avatar
Car: 1963 Nova 2dr
Transmission: 350 Turbo
Axle/Gears: 342
I am new to the world of HP. I have started a complete restoration project ( 63 Nova 2dr). I am now in the engine stage but I'm confuse and in desperate help.
Here are my engine Spec...
Block 4 bolt main. Refresh with a .040 over bore.
5.0 Heads 66cc
Stock Crank
Trans 350 Turbo stalconverter
Rear-end from 89 GTA Trans AM gear are 342
Factory Intake and TPI items from a 88 Z-28
I want to optimize the power of the TPI system and of the engine. The car is going to be a daily driver but with attitude.
If you guys can tell me what set-up would help me get to or closer to 350hp at the rear wheels I would appreciated.
What Component should I buy
Cam
Valve
Runners
anything that would benefit the project, please let me know.
Old Feb 15, 2006 | 12:03 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
Since you don't have to worry about smog, i would get a stealth ram. That will give you more power than any intake or runner swap. Then get a set of heads, i like the trick flow heads, a cam, and full exhaust. That will give you probably 350 at the wheels. You'll also be streetable with something like a zz9 cam. You'll also have to learn to tune that ecm or have someone do it for you.
Old Feb 17, 2006 | 09:00 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
350 rwhp on TPI will take lots of time, work and tuning
ZZ4 cam (very streetable)
AFR or Trickflow heads
9.5:1 compression
Edelbrock Lower intake
SLP runners ported
Ported Plenum
1 3/4' headers
True Duals if possible
Upgraded Igniton and Fuel Systems
Ed Wright Tune
Not really for horsepower, but they help TPI significantly:
3.5x gears
Bigger Cooling fans
A good flowing "cold" intake
scottmoyer
Sep 5, 2015 09:33 AM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
