Ford injectors (Doc?)
Old Feb 15, 2006 | 05:00 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
I just bought 24# injectors part 397-M-9593-A302 (Blue top). I wanted the EV1's from Summit, part FMS-M-9593-A302 (red top). I figured if the part number was the same (not considering the first part which is designated for distribution) that I would have got the red tops. I got the blue tops. Does this mean I got the old SVO style? Should I return them for the red tops?
Old Feb 15, 2006 | 07:17 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I just went out to check my car, I have the blue tops. I have had these 24# injectors for over 7 years. BTW: I know that they are EV1 style.
I would say that you cant go wrong with the blue tops. And I did not know that 24# Ford injectors came with blue tops and red tops. I do know that you want the A302 suffix number.
Old Feb 15, 2006 | 07:18 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
The EV1s and EV6s differ in the overall size of the injector and in the connector. We have to use the EV1 style.
Old Feb 15, 2006 | 10:42 PM
Guest
Guest
Posts: n/a
Red are 30#, I have a set.
Old Feb 16, 2006 | 08:31 AM
Car: 1987 Iroc-z
Thanks guys - I got screwed up because I know that Ford is getting away from the "SVO" name. So I assumed that they changed the injectors in design as well and that they changed the blue to red. Summits picture shows red for 24# injectors. After further review, I noticed Summit uses that picture for all of Fords Injectors. I guess I just needed a sanity check. I didn't want to miss out on a new design if one existed. As usual, you guys have straigtened me out and I appreciate it very much. Now I can finally get rid of my crap Accels but that is another story... Being in Buffalo, I will let you know how they work out in spring, my car is still in my bros barn.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
