91 z28 305 -> 350, what do I need?
Old Feb 17, 2006 | 11:51 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Computer wise?
Folks in my engine swap thread suggested Id need a 350 PROM (along with injectors, knock sensor, and module).
So does that mean that I just pick up the GM 350 PROM chip? Straight from GM? Or can I (should I) just get one of those aftermarket chips (JET, Hypertech, etc)?
Are they the same thing?
And if I did decide to get an aftermarket computer, chip, whatever...which one do you all suggest? JET? (heard bad things about hypertech)
Could I get a list of suggestions regarding computer related parts Ill need for this swap?
Thank you!
Old Feb 18, 2006 | 12:59 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
IF u are going to a STOCK 350 with everything on the engine set up as a 350 than a stock memcal would work fine.
305 =19# inj, 350 = 22# inj from the factory.
If you are adding a cam, ported heads, etc, it is still best to run the closest applicable factory memcal and components to your combo.
So depending on what u r doing, U would need the memcal, inj, knock sensor.
Check out the Guidebook sticky up top as far as leanring how to tune and what u need to do it.
The aftermarket chips are garbage.
There is a decent amount to be had in even tuning an otherwise stock application.
later
Jeremy
Old Feb 18, 2006 | 01:23 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Thanks Jeremy,
Lets say that I dont have the time to custom tune anything just yet. Lets say I need a reliable car, and I need it now.
Im buying a "stock engine in a box", and just need a computer to run the show for a while, and then might tune and tweak some other day.
Do I just pick up a GM 350 memcal? And is that GM part # 1227730?
All the stuff Ive been able to locate, is all greek to me, and honestly, I dont have the time to learn all this stuff just now, I just need to know where to go to get the part I need
I cant seem to find this monster (1227730) for sale anywhere...
Old Feb 18, 2006 | 01:55 AM
3.8TransAM's Avatar
No tuning content, its going over to the TPI board then :-)
Hit a junkyard and check out late 80 early 90 FWD cars. Berretta's and the like had them. think the Cav's did too.
later
Jeremy
Old Feb 18, 2006 | 02:06 AM
Guest
Guest
Posts: n/a
1227730 is the ecm, the chip is inside, different part number. There's a list of numbers on the thirdgen.org faq or tech section or somewhere from the front page. You should already have the 730 ecm in there, so just need the chip/prom/memcal/whatever you wanna call it, plus the other aforementioned stuff.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
