failing fuel pump???
Old Feb 20, 2006 | 01:27 PM
firehawk35's Avatar
Car: 88 GTA
Transmission: 700 R4
OK this is driving me a lil crazy. I have a 88 GTA 5.7. I believe the fuel pump in on its last legs. But am unsure and I would like a opinion or two before I change it out. My problem is as follows. A while back I believed my pump had died. After shutting down the car at home it would not start again. no sound at all from pump. I changed the relay and checked the fuses for a easy answer. But the easy path did not work. Still no pump. I let it sit for awhile till I had time to change the pump, Well heres where I get confused, I jumped in the car the other day and to my suprize it started right up, ran fine till I shut it off. then when I would try to start it again the pump would prime the car would start then die. did this several time before the pump would not run anymore. So I left it alone again. Next day I put on a pressure tester on it and the car fired right up again 40psi. Ran till I shut it off. tried to start it again pump primed to 40psi car started then pressure dropped quickly to 0psi. Did this two or three more times untill I quit trying.
Sometimes the pump works sometimes not... Is this the sign of a bad pump or something else. ANY ideas would be welcome.
Old Feb 20, 2006 | 08:32 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Wow, deja vu!
2 weeks ago my 89 vette with a 4000 mile old pump did exactly just that. Once the pump had cooled off it would work for awhile, then cut out again. I threw a FP on from Autozone and all is well. I believe they are made by Airtex which manufactures most pumps out there.
Old Feb 21, 2006 | 01:06 AM
firehawk35's Avatar
Car: 88 GTA
Sounds very similar , but mine dosenot always start when cold. Works better when weather is warmer. But I am leaning towards the pump. Thanks for the reply
Old Feb 21, 2006 | 10:09 AM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
I had a 87' with a similar problem.. Turned out it wasn't the relay but damn close.
One of the pins in the relay socket wasn't making a good connection.
When it doesn't start, try listening of feeling for the relay to click as someone turns your ignition to on..
Old Feb 21, 2006 | 12:11 PM
firehawk35's Avatar
Car: 88 GTA
Thanks for the idea scoob. I will give it a try and let ya know. Maybe with any luck
Old Feb 21, 2006 | 05:37 PM
1bdbrd's Avatar
Car: 1991 Trans Am
i have a quesiton ive asked on here before and never got an answer. i think my pump is dying as well. i installed a holley AFPR and after that i would have a bad hesitation (it wouldnt rev it was so bad) at about 5k on the street ant 5k at the track. i turned the pressure down and it went away on the street. but still did it at the track. then i installed some shorty headers and about 3 months later it started doing it again on the street. now it wont rev above 3500 at wot or about 4500 at part throttle. i went ahead and purchased a walbro 255lph pump that i should get in a few days but im hoping its my pump. sound like my pump?
Old Feb 21, 2006 | 11:19 PM
firehawk35's Avatar
Car: 88 GTA
Well Looks like my wires to my relay are really nasty gonna clean them up and make sure the contact is real good. But I ran into another issue. I think I cooked starter silenoid . while trying to crank it up the starter turned over the motor then all of a sudden disengaged the flexplate and was just spinning till I unhooked the battery. Just my luck. Gonna pull the starter tomorrow then continue with the fuel pump issue.
Old Feb 22, 2006 | 02:40 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
sounds like the pump. my 88 GTA had the same issue a few months ago. it was kinda working, but i was going to replace the pump anyway.. died at the auto parts store when i was buying a new pump
Old Feb 28, 2006 | 07:45 PM
prevarications's Avatar
How much did the pump run you? I have an 85 IROC...do you know if its located in the gas tank?
Thanks, Rick
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
