bump up to a larger throttle body?
Old Feb 25, 2006 | 07:34 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
this is more of an after-thought, i suppose, but with installing a larger cam with more lift and having the heads done, should i go to a larger bore throttle body? stock is on there right now, guess it's a 44 and running good with it, but was contemplating a 48... thoughts? opinions? still has stock plenum and intake, btw, on my 350 TPI.
Old Feb 25, 2006 | 10:37 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
A quick vacuum test in the plenum during a WOT pass will give you the answer. If you're getting an inch or more vacuum at WOT then you could benefit from enlarging your greatest restriction ahead of the plenum (which could possibly be the throttle body).
Old Feb 25, 2006 | 12:44 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
On a TPI engine the stock throttle body is 48mm. You could upgrade to a 52mm or 58mm....i suggest the 58mm b/c its the same price and the more mods you do, then more the bigger throttle body will be useful. However, the biggest bottle neck on the TPI system is the base. If you haven't changed that.....that would be a great first start along with the throttle body.
Old Feb 25, 2006 | 02:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I would spend the 300-400$ elsewhere first.
U will see barely if any gains on a stocker.
Spend the $$$$ on headers/catback or base and runner first.
Lot better results for your $$$$
later
Jeremy
Old Feb 25, 2006 | 05:03 PM
Car: '91 Z28
Axle/Gears: 323's
i have headers and catback already and plan to stay pretty much stock for the most part for now so i guess i'm pretty well set with what i have. i was thinking stock was 44, not 48, but now that YenkoST mentioned it, that does ring a bell... thanks for the replies...
Old Mar 1, 2006 | 08:53 AM
V6camaroman's Avatar
305sbc thanks for that tid bit of info. i had never heard that before. makes me wanna go test mine now to see if my stock tb is holding me back.
Old Mar 1, 2006 | 09:20 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Put the money elsewehre. You'd see more gains with something like a good converter and gears. Ignition upgrade, underdrive pulleys, lca's and relocation brackets, panhard rod, the list goes on. TB isn't the bottleneck of the engine, the stocker will flow enough air to support those heads.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
