What Injector for ZZ4-cammed 355?
Old Feb 21, 2006 | 08:10 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Hey all,
I know I'll need to replace my 19 lb. SVOs when I swap in the 355, but should I go for 22 lb. or 24 lb. injectors? The 355 we're assembling will be around 9.7:1 compression with a ZZ4 cam, ported plenum, and SLP runners.
TIA!
Old Feb 21, 2006 | 10:34 AM
91Z28-350's Avatar
22 (stock TPI 350) or 24 should be fine.
Old Feb 21, 2006 | 01:05 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am runnngi 22lb ones . They will support 400ish hp I keep hearing. Get an AFPR to help
Old Feb 21, 2006 | 05:18 PM
Shagwell's Avatar
Car: projects.......
I've run as high as 425 hp on stock 22's. - so yes, another vote for 22lb'er...aftermarket 22. - I'm another person who recommends staying away from accel though....
Old Feb 21, 2006 | 05:54 PM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
I use 24 lb/hr ford motorsport injectors. Just my two cents and don't waste your money on anything that has Accels name on it.
Old Feb 21, 2006 | 06:34 PM
Car: 1988 Monte SS
Thanks for the input guys. I've found some reasonably priced LT1 22 lb. injectors, so I figured I'd make sure they work before I spent the coin.
Thanks again all!
Old Feb 22, 2006 | 09:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Install the 24#/hr Ford injectors and also a Holley AFPR. Those injectors will allow you to make up to 450 Hp at higher fuel pressures. At near stock fuel pressure, you may not need a new Eprom. However, at higher fuel pressures and higher Hp output, a custom Eprom would be a requirement.
Old Feb 24, 2006 | 12:29 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
no BS go to the 24lb motorsports!
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
