v6 throttle issue
Old Feb 22, 2006 | 07:58 PM
TpiTony's Avatar
Car: 1991 Camaro Z28
Engine: 305 Tpi (and not the average)
Transmission: 5 spd warner
v6 throttle issue
My cousin has 92 rs with a 3.1 liter. The car runs good for about 10 minutes, then starts to hesitate on takeoff and during throttle increase but when reaches speed its ok. I have replaced the fuel filter and the tps sensor. Please give me a hand here.
Thanks,
Tony
Old Feb 23, 2006 | 01:26 AM
Vader's Avatar
Watch for replies in this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=348247
I copied it to the V-6 Forum so it would get better exposure.
Have you checked fuel pressure? You were on teh right track with the filter change, and now that it has a good filter, getting an accurate pressure reading would be good.
Old Feb 23, 2006 | 09:26 AM
TpiTony's Avatar
Hmmm..........
Well it runs fine for the first 10-15 miniuts. Why would it be fuel pressure. (Dont think im calling you out on this one) I just wont know if i dont ask. Just trying to learn here.
Thanks,
Old Feb 23, 2006 | 10:57 AM
Vader's Avatar
It's a good question. It's possible that the pump starts losing pressure after heating, or the FPR changes after soaking up some engine heat. Knowing that the fuel pressure is adequate while this is happening would eliminate one variable.
Weak ignition can also cause or contribute to this kind of phenomenon. A heating ignition coil or pickup coil may be indicated, but instead of hesitation, plain old misfire is usually the result.
theshackle
Sep 17, 2020 08:26 AM
Prodigious
Oct 4, 2015 11:20 PM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
