v6 throttle issue
Old Feb 22, 2006 | 07:58 PM
TpiTony's Avatar
Car: 1991 Camaro Z28
Engine: 305 Tpi (and not the average)
Transmission: 5 spd warner
v6 throttle issue
My cousin has 92 rs with a 3.1 liter. The car runs good for about 10 minutes, then starts to hesitate on takeoff and during throttle increase but when reaches speed its ok. I have replaced the fuel filter and the tps sensor. Please give me a hand here.
Thanks,
Tony
Old Feb 23, 2006 | 03:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'll give you a hand- (clap) (clap) (clap)
Ha, ha, okay, enough joking- how's the rest of the car doing? Spark plugs, spark plug wires, air filter, IGNITION TIMING, distributor cap/rotor, PCV valve, etc?
Was the TPS giving a bad reading?
Oh, a bad fuel pump can give those kind of symptoms too...
And with a nod to KED85/Karl (RIP), make sure your cousin's alternator is putting out the correct voltage. Engine running and in neutral, you should see 13.8 volts at the battery with a handheld meter.
Old Feb 26, 2006 | 03:36 PM
TpiTony's Avatar
Changes all kinds of ****
I figured that I should chang a few thing as I go to eliminate problems since its a old car. I replacer the IAC, PCV, TPS, coolant temp sensor and the fuel filter. When I did that fuel shot across the garage floor so I fdont think its the fuel pump. And this problem only happens when the car warmes up. The dist is new when we bought the car a few months back. I am leaning twards a plugged cat.
I dunno,
Thanks for the imput
tony
Old Feb 26, 2006 | 03:39 PM
TpiTony's Avatar
Oh and!
The EGR solonoid is new too.
Old Feb 27, 2006 | 02:37 PM
BitchinRS's Avatar
Just becuase the fuel came out like a shot does not mean the pump is ok. Only way to make sure is to check the presure. Presure needs to be between 43 - 47PSI.
You can have 20PSI and still shoot fuel across the garage. Also presure needs to be maintained. There is a certain amount of presure drop allowed once the car is started, but if I remember right it was only some thing like 2 -3PSI.
I have a '92 3.1 and had these same exact symptoms when my last pump died. It did this for a couple of weeks then suddenly I couldn't get past 30MPH.
Checked fuel presure and it came in at 15PSI.
11 1/2 hours, and bunch swearing later my pump was replaced and car ran like a champ again.
theshackle
Sep 17, 2020 08:26 AM
Prodigious
Oct 4, 2015 11:20 PM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
