cold start issue
Old Feb 23, 2006 | 07:49 PM
brickwahl681's Avatar
Car: 88 camaro, 86 iroc, 2000 silverado z71
Engine: 355, 305, and 5.3
Transmission: manual, automatic
cold start issue
I have a 86 iroc with a tpi 305. The only way it will start when it is cold is to push the accellerator pedal down about half way and then crank it up. The motor is got 4,000 miles on a rebuild. All of the sensors have been replaced including the mass air. It will soon recieve a 320hp carberated 355 if I can't fix it. Maybe there is a tpi goo roo in or near Mooresville North Carolina that I can talk to..
Old Feb 23, 2006 | 08:24 PM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
You have the horrible cold start system. I have dealt with these issues over and over again. Make sure that the TPS voltage is in check then its time to cover the cold start. Make sure that your cold start switch is in check ( in the front of your base manifold) also make sure that the connector that goes the cold start switch is in good shape and its getting the proper voltage from the ECM. Then make sure that the cold start injector has the proper ohms, even if it does it may be jammed full of junk. I assume you have replaced the coolent temp sensor for the ecm. Thats about all I am going to write, hope it helps.
Old Feb 24, 2006 | 10:49 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
oh lord, talk about cold start. my car is a total nightmare. things i'm gonig to recheck are,
MAF
Burnoff rely
FP rely
Ohm all injectors,
I've aready calabrated the TPS and replaced the IAC along with cleaned TB
Test FP
I have feeling it's my MAF
Old Feb 24, 2006 | 10:09 PM
cold start
I've done most of that. replaced all the sensors and injectors. I'm starting to think that it might be in the harness it self
Old Feb 25, 2006 | 04:25 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
DID you replace the CTS sensor ? It really could be it .
Sounds like sound advice .
Old Feb 25, 2006 | 05:01 PM
cold start issue
do you have to specs for the voltage and ohms of the cold start switch and cold start injector? The tps sensor is in check. I set the voltage on that using a snap-on scanner
Old Mar 3, 2006 | 02:44 PM
CochinoFilipino's Avatar
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Re: cold start issue
I need that too.
[Edit]Found info here: http://tpiparts.net/85_89_maf_sensors/
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
