EGR on TPI
Old Feb 25, 2006 | 08:11 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
EGR on TPI
will blocking off the EGR..a) trigger a code?, b) affect performance?, c) fail a sniffer test? i'm retro fitting tpi on a 355 in my '83 cfi z-28...
Old Feb 25, 2006 | 09:42 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Some people have reported getting a code, but many do not, and it's harmless anyway. Generally performance improves without EGR. The removal increases ease of tuning and troubleshooting.
Old Feb 25, 2006 | 02:07 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Only proper way to disable EGR is to block it off and also turn it off in the code.
More details for the code end on the DIY PROM board.
Just blocking it off, stops the exhaust gas from entering the engine, but the routines still run in the computer, such as lenaing it out slightly and advancing the timing when egr is still active in the ecm/code end.
later
Jeremy
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
