Starting trouble
Old Mar 2, 2006 | 01:09 PM
92PrpleCamaroRS's Avatar
Car: 1992 Camaro RS
Transmission: T5 Transmission
Axle/Gears: 10 bolt 277 posi rear end
Starting trouble
Hey what is up, I have just recently installed a 350 small block with a tuned port itake on my camaro. I had to switch over to a 91-92 camaro wiring harness. I got everything hooked up and all the accerssories work but when I turn the key over nothing happens. I also put in a t5 transmission and the wiring harness is built for the manual tranny. so i tried to reuse the neutral safety swith in the car, and also i have taken the purple starter wire and green wire coming from the relay and tied them together. i still don't have power going to the ignition. there is not power at the relay. i have not hooked up the field wire from the alternator and i heard that maybe the cause. i have this orange wire coming out of the harness right by the ac compressor on the pass side and i don't know where it hooks up at. if anyone has a picture of that side of teh engine bay or can give me some information that would be most appreciative, these damn wiring schematics don't work for ****...
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
